Home » Categories » *HOWTOs » Nagios Log Server
Using An Output To Create Nagios XI Passive Objects
This document describes how to use a Nagios Log Server Output to create Passive Host and Service objects in Nagios XI. This document provides an example of how Nagios Log Server Outputs can perform tasks on the log data it receives.
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Analyzing Logs
Viewed 2065 times since Fri, Nov 8, 2024
How To Export Or Schedule Reports In Nagios Log Server
Viewed 2050 times since Fri, Nov 8, 2024
Alerting On Log Events
Viewed 1759 times since Fri, Nov 8, 2024
Changing Data Store Path
Viewed 1739 times since Fri, Nov 8, 2024
How To Create A Nagios Log Server Instance In The Amazon EC2 Cloud
Viewed 1493 times since Fri, Nov 8, 2024
Sending NXLogs With SSL/TLS
Viewed 1641 times since Fri, Nov 8, 2024
Monitoring Squid Proxy Server With Nagios Log Server
Viewed 1839 times since Fri, Nov 8, 2024
How to Backup and Restore the Nagios Log Server
Viewed 2141 times since Fri, Nov 8, 2024
Monitoring Linux System Logs using Nagios Log Server
Viewed 2118 times since Wed, Nov 6, 2024
Sending Mac OS X Logs To Nagios Log Server
Viewed 1477 times since Fri, Nov 8, 2024
