Home » Categories » Products » Nagios XI » Documentation » Architecture
Nagios XI - Recurring Downtime System
Recurring Downtime Overview
Nagios XI gives you the ability to schedule downtime that re-occurs on a regular basis.  This is called recurring downtime.  This document describes the components of the recurring downtime system, as well as troubleshooting information.
Recurring Downtime Architecture
An architectural overview of the recurring downtime system is shown in the image below.  A detailed description of each step follows later.
The recurring downtime system shown in the image above works as follows:
  1. When you use the Nagios XI UI to define recurring downtime schedules, the schedules are written to the /usr/local/nagios/etc/recurringdowntime.cfg file on your XI server.
  2. The recurring downtime cron job (/usr/local/nagiosxi/cron/recurringdowntime.pl) reads the config file periodically and determines if any hosts or services should go into downtime.
  3. If the cron job determines that a host or service should enter downtime (based on the schedule you defined in the web UI), it will send a downtime command to the Nagios Core monitoring engine via its external command pipe (/usr/local/nagios/var/rw/nagios.cmd).
  4. The Nagios Core monitoring engine reads the external command pipe and puts the required host or service into scheduled downtime.
Troubleshooting Problems
If you have problems with recurring downtime not working properly, check the following items:
  • Ensure the recurring downtime configuration file has the correct ownership and permissions, as shown below:
    • -rw-rw-r-- 1 apache nagios 0 Jan  2  2012 /usr/local/nagios/etc/recurringdowntime.cfg
  • Ensure the recurring downtime configuration is being written to the /usr/local/nagios/etc/recurringdowntime.cfg file
  • Make sure the recurring downtime cron job is running properly and not returning errors.  You can do this by examining the recurring downtime log file (/usr/local/nagiosxi/var/recurringdowntime.log)
Final Thoughts
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - How to Manage Remote Nagios XI Servers
Viewed 7345 times since Thu, Jan 28, 2016
Nagios XI - Terminology Overview
Viewed 6555 times since Sun, Feb 8, 2015
Nagios XI - Performance Data Architecture
Viewed 10143 times since Wed, Jan 28, 2015
Nagios XI - Manage MIBs Architecture
Viewed 17332 times since Tue, Feb 10, 2015
Nagios XI - High Availability and Failover Solutions for Nagios XI - NWC14
Viewed 10788 times since Thu, Feb 4, 2016
Nagios XI - Cron Jobs
Viewed 12800 times since Thu, Feb 5, 2015
Nagios XI - Switch and Router Wizard Architecture
Viewed 11396 times since Fri, Feb 6, 2015
Nagios XI - Architecture Overview
Viewed 16010 times since Tue, Jan 27, 2015
Nagios XI - Under the Hood - NWC15
Viewed 6249 times since Thu, Feb 4, 2016
Nagios XI - Maximizing Performance In Nagios XI
Viewed 8241 times since Thu, Jan 28, 2016
