I kicked off an update hours ago, stuck on:
"Update in progress. Please wait. Update may take a few minutes."
Thoughts on what might be going on here?
Update in progress. Please wait. Update may take...
benjaminsmith
Re: Update in progress. Please wait. Update may take...
Hello @rkane,
If the update has stalled, please log into the terminal as root user and run a manual upgrade instead.
Also, if you need to reset the upgrade status in the Web Interface, please follow the instructions below.
https://support.nagios.com/kb/article/n ... e-851.html
cd /tmp
rm -rf nagiosxi xi*.tar.gz
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./upgrade
Worked great, thank you. Feel free to close this thread.
benjaminsmith
Glad to hear. We'll locked this up.Worked great, thank you. Feel free to close this thread.
Thank you for using the Nagios Support Forum.
