I have problem updating my nagios xi..
"Update in progress. Please wait. Update may take a few minutes" All the time
Can you help me?
Regards
Problem update NagiosXI Again
benjaminsmith
Re: Problem update NagiosXI Again
Hell @eSailVite,
Please follow the article below to clear the "Upgrade in progress" message and let me know if the issue is resolved.
Nagios XI - Reset Upgrade Status In Web Interface
If the upgrade was not successful, try logging into the terminal, run the following commands to upgrade manually:
cd /tmp
rm -rf nagiosxi xi*.tar.gz
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./upgrade
It`s the third I do this.. Have I upgrade manually forever? Can you resolve my problem, please?
Regards
Regards
benjaminsmith
Hi @eSailVite,
Sorry about the inconvenience this is causing you. It's a known issue and not easily repeatable. We are planning to re-work the GUI upgrade in Nagios XI 5.7 to correct this. In the meantime, please use the manual upgrade on your system.
Thanks for your patience and let me know if you have any questions.
ok, thanks so much
Locking threadeSailVite wrote:ok, thanks so much
