Check for updates hangs on Update in progess
Current release Nagios XI 5.6.9. Going to start the update to latest level. Selected Check for Updates from Admin window. The update in progress line is display with a spinning wheel but no activity is being noted. The update in progress has been sitting with the spinning wheel for over 15 minutes.
Re: Check for updates hangs on Update in progess
Killed session doing the update and attaching current profile
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum.
It appears from your profile, that you are encountering some database errors. I recommend that you start by repairing the Nagios database with the following command.
ref= https://assets.nagios.com/downloads/nag ... tabase.pdf
Then I recommend doing a manual upgrade using the following set of commands.
ref= https://support.nagios.com/kb/article/n ... e-851.html
/usr/local/nagiosxi/scripts/repair_databases.shThen I recommend doing a manual upgrade using the following set of commands.
cd /tmp
rm -rf nagiosxi xi*.tar.gz
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./upgradeAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
