Getting Error: Could not connect to IP Connection reset by peer
Post Reply
lrnnetops
Post by lrnnetops »
Hi Team,
We are experiencing the following error after adding couple of nodes in Nagios XI. Please help us in resolving this error.
"CHECK_NRPE: Error - Could not connect to 10.x.x.x: Connection reset by peer"
kg2857
Re: Getting Error: Could not connect to IP Connection reset by peer
Post by kg2857 »
Is nrpe or xinetd running on the remote hosts?
Is allowed_hosts set right in nrpe.cfg or the xinetd config?
Is port 5666 open on the hosts?
lrnnetops
Post by lrnnetops »
We are using xinetd, after starting xinetd now below error is coming.
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with 10.x.x.x: 1
ajcoil
Post by ajcoil »
Hello @lrnnetops,
Thank you for reaching out!
Though the environments are a little different, I would check out the forum thread below as I believe it could provide some assistance!
viewtopic.php?t=57425
If you have any other questions, comments, or concerns, feel free to reach out!
Post Reply
