| Home »
Categories
» Products » NRPE » Troubleshooting » Common Problems |
CHECK_NRPE: Error - Could not connect to xxx.xxx.xxx.xxx: Connection reset by peer |
Article Number: 616 | Rating: 1.1/5 from 17 votes | Last Updated by tlea on Fri, Jul 14, 2017 at 4:01 AM
Problem Description
This KB article addresses the following NRPE error:
Troubleshooting The Error
Please refer to the following KB article to define the Nagios XI server's IP address as being allowed to communicate with NRPE:
NRPE - CHECK_NRPE: Error - Could Not Complete SSL Handshake
Final Thoughts
Posted by: tlea on Fri, Jul 14, 2017 at 4:01 AM. This article has been viewed 30281 times. Filed Under: Common Problems |
Have a question? Try our Forums! | Give Feedback |
1.06 (17)
Article Rating (17 Votes)
Rate this article
| Related Articles
Disabling Port 113 IDENT Requests
Viewed 8562 times since Tue, Mar 12, 2019
NRPE - No Output Returned From Plugin
Viewed 18145 times since Mon, Jul 17, 2017
NRPE - Packet Size Explained
Viewed 35698 times since Thu, Jun 30, 2016
