Home » Categories » Products » NRPE » Troubleshooting » Common Problems
NRPE - Connection Refused By Host
Problem Description
This KB article addresses the following NRPE error:
Assumed Knowledge
The following KB article contains an explanation of how NRPE works and may need to be referenced to completely understand the problem and solution that is provided here:
NRPE - Agent and Plugin Explained
Troubleshooting The Error
This error usually relates to port/firewall issues or improperly configured "allowed_hosts" directives.  Please refer to the following KB articles for the relevant troubleshooting steps:
NRPE - CHECK_NRPE: Error - Could Not Complete SSL Handshake
NRPE - CHECK_NRPE: Socket Timeout After n Seconds
Final Thoughts
1 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Viewed 108782 times since Sun, Jul 16, 2017
NRPE - Turn Off XINETD Logging On Success
Viewed 15514 times since Tue, Mar 7, 2017
Viewed 133256 times since Fri, Jul 14, 2017
Disabling Port 113 IDENT Requests
Viewed 8561 times since Tue, Mar 12, 2019
NRPE - Connection Refused Or Timed Out
Viewed 11583 times since Mon, Jul 17, 2017
How To Clear Solaris Service Maintenance Status
Viewed 38432 times since Mon, Mar 6, 2017
NRPE - Command ’[Your Plugin]’ Not Defined
Viewed 11621 times since Mon, Jul 17, 2017
NRPE - CHECK_NRPE: Received 0 Bytes From Daemon. Check The Remote Server Logs For Error Messages
Viewed 14229 times since Mon, Jul 17, 2017
NRPE - General Troubleshooting Tips
Viewed 21575 times since Mon, Jul 17, 2017
NRPE - Return Code Of 126 Is Out Of Bounds - Plugin May Not Be Executable
Viewed 10258 times since Fri, Jul 14, 2017
