Home » Categories » Products » NRPE » Troubleshooting » Common Problems
CHECK_NRPE: Error - Could not connect to xxx.xxx.xxx.xxx: Connection reset by peer
1.06 (17)
Article Rating (17 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
How To Clear Solaris Service Maintenance Status
Viewed 38392 times since Mon, Mar 6, 2017
NRPE - Command ’[Your Plugin]’ Not Defined
Viewed 11597 times since Mon, Jul 17, 2017
NRPE - CHECK_NRPE: Error - Could Not Complete SSL Handshake
Viewed 133225 times since Fri, Jul 14, 2017
NRPE - Packet Size Explained
Viewed 35668 times since Thu, Jun 30, 2016
NRPE - UNKNOWN: No Handler For That Command
Viewed 17176 times since Mon, Jul 17, 2017
NRPE - Return Code Of 126 Is Out Of Bounds - Plugin May Not Be Executable
Viewed 10253 times since Fri, Jul 14, 2017
NRPE - Connection Refused Or Timed Out
Viewed 11563 times since Mon, Jul 17, 2017
NRPE - ERROR: Missing Argument Exception
Viewed 6890 times since Mon, Jul 17, 2017
NRPE - CHECK_NRPE: Received 0 Bytes From Daemon. Check The Remote Server Logs For Error Messages
Viewed 14215 times since Mon, Jul 17, 2017
Disabling Port 113 IDENT Requests
Viewed 8549 times since Tue, Mar 12, 2019
