Home » Categories » *HOWTOs » Nagios XI
How To use Nagios XI to Monitor Active Directory
To monitor Active Directory, we have created a wizard that connects through LDAP to connect users that already have a user account in Microsoft. This makes it easy to connect to Nagios XI so you can start monitoring quickly and efficiently.
The following Video Guide and Documentation covers the Monitoring Active Directory using LDAP in Nagios XI.
Video Guide:
Additional Documentation:
Monitoring Active Directory with LDAP
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
How to Configure Contacts in Nagios XI
Viewed 2435 times since Wed, Nov 27, 2024
How To install additional Configuration Wizards in Nagios XI
Viewed 1531 times since Mon, Nov 11, 2024
How To Monitor Linux using the Nagios Remote Plugin Executor (NRPE)
Viewed 2729 times since Tue, Nov 5, 2024
How To configure your Timezone in Nagios XI
Viewed 1909 times since Mon, Nov 4, 2024
How To Change The System Time
Viewed 2549 times since Fri, Nov 8, 2024
How To Monitor Windows Using SNMP In Nagios XI
Viewed 2551 times since Fri, Nov 8, 2024
How To Use Scheduled Reports
Viewed 1771 times since Fri, Nov 8, 2024
How To Monitor Linux using the Nagios Cross Platform Agent (NCPA)
Viewed 3174 times since Tue, Nov 5, 2024
How To use Dashboards in Nagios XI
Viewed 2206 times since Thu, Nov 7, 2024
How To utilize Standard Edition (SE) Reports
Viewed 1350 times since Fri, Nov 8, 2024
