Home » Categories » Multiple Categories
Nagios XI - Monitoring Performance Counters in Nagios Using NCPA
This article describes how you can monitor Windows Performance Counters in Nagios XI. This article will show you how to do this using Core Configuration Manager (CCM).
This article is going to focus on the following performance counter:
"\Memory\Available MBytes"
Which is referenced by NCPA in the following format:
'windowscounters/Memory/Available%20MBytes'
Note: When spaces are involved, %20 is required to emulate the space:
Warning threshold will be set to 500 and critical 256.
Requirements
You need to install NCPA to be able to monitor performance counters in Nagios XI. Please refer to the installing NCPA KB article if you have not already done so.
You will also need to have the host already monitored by Nagios XI (you can do this using the NCPA wizard). In this example, the host is called win7-01 and the host has the token uumrdrd3p704.
Create The Service
Click the Configure menu
Click Core Configuration Manager
In the left pane under Monitoring click Services
Click the Add New button
Populate the fields on each tab as follows:
Common Settings
Config Name win7-01
Description Memory Available
Manage Hosts button Select win7-01
Manage Templates button Select xiwizard_ncpa_service
Check command check_xi_ncpa_agent
$ARG1$ -t 'uumrdrd3p704' -P 5693 -M 'windowscounters/Memory/Available%20MBytes' -w 500: -c 256:
Check Settings
Check interval 5
Retry interval 1
Max check attempts 5
Check period xi_timeperiod_24x7
Alert Settings
Complete any notification options as required
Click Save
Click Apply Configuration
Now the settings have been applied, click the magnifying glass on the right of the menu bar.
Search for Memory Available
In the search result, click on the new service Memory Available
You should see something like the following:
This completes monitoring a performance counter using NCPA.
Summary
At this point you should have an understanding of how to configure Nagios XI to monitor performance counters.
Final Thoughts
1.67 (6)
Article Rating (6 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Core Config Manager - Service Groups
Viewed 11359 times since Sun, Jul 30, 2017
Nagios XI - Special Characters
Viewed 30562 times since Tue, Apr 25, 2017
Nagios XI - Restoring Default Configuration
Viewed 14675 times since Tue, Jan 26, 2016
Nagios XI - Integrating autoIT With Nagios
Viewed 7681 times since Wed, Jan 27, 2016
Nagios XI - How To Monitor Website Defacement With Nagios XI
Viewed 7187 times since Thu, Jan 28, 2016
WebInject Instructions
Viewed 14962 times since Tue, Mar 16, 2021
Nagios XI - What Is A Performance Counter?
Viewed 13156 times since Thu, Jan 14, 2016
Nagios XI - How To Use Deadpool In Nagios XI
Viewed 6047 times since Thu, Mar 16, 2017
Nagios XI - Using The Core Config Manager For Service Management
Viewed 13574 times since Mon, Aug 8, 2016
Nagios XI - Using Nagios XI As A Security Tool - Software Versions
Viewed 5791 times since Wed, Jul 19, 2017
