Home » Categories » Multiple Categories
Nagios XI - Monitoring VMware Virtualization Using vMA - NWC14
NOTE: Monitoring VMware virtualization using vMA is obsolete. Please see Monitoring VSphere.
Anyone who has tried to monitor VMware virtualization using the existing Nagios plugins available will have experienced one thing ... your Nagios host becomes unresponsive as you monitor more and more objects. This has to do with the VMware SDK, it's CPU and memory hungry. The box293_check_vmware plugin is a new plugin that has been written from the ground up to overcome this issue. This plugin is NOT designed to be run on your Nagios host, instead it is offloaded to the VMware vSphere Management Assistant (vMA). This presentation will demonstrate the capabilities of the plugin along with how to get it up and running.
Final Thoughts
1 (1)
Article Rating (1 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Running Auto-Discovery Jobs
Viewed 7590 times since Wed, Jul 19, 2017
Nagios XI - Host and Service Details Overview
Viewed 8475 times since Wed, Jan 27, 2016
Nagios Log Server - Using An Output To Create Nagios XI Passive Objects
Viewed 7011 times since Thu, Sep 7, 2017
Nagios XI - Monitoring VMware With Nagios XI
Viewed 16284 times since Thu, Jan 28, 2016
Nagios XI - How to Integrate SNMP Traps With Nagios XI
Viewed 22216 times since Thu, Jan 28, 2016
Nagios XI - Receiving IPv6 SNMP Traps
Viewed 11662 times since Thu, Apr 28, 2016
Nagios XI - How to Monitor Apache Cassandra Distributed Databases
Viewed 9799 times since Thu, Jan 28, 2016
Nagios XI - Using Recurring Downtime
Viewed 6038 times since Wed, Jul 19, 2017
Nagios XI - How SNMP Traps Work
Viewed 7595 times since Mon, Nov 18, 2019
Nagios XI - Core Config Manager - How It Works
Viewed 6616 times since Sun, Jul 30, 2017
