Home » Categories » Multiple Categories
Nagios XI - Problems With Scheduled Backups At Midnight
Problem Description
It has been observed that scheduling backups of Nagios XI at midnight (00:00) will create multiple Nagios parent processes to be unintentionally created. Multiple Nagios parent processes causes many unusual problems.
Explanation
At midnight the Nagios process performs it's daily log file rotation. The Nagios process moves the old log file to the archives directory and creates a new nagios.log file. When it creates the new log file it also dumps the current state of every host and service object into the new nagios.log file. In larger deployments of Nagios XI this process may take several minutes.
If you schedule a Nagios XI backup to occur at midnight, the first step in the backup script is to restart the nagios service. The nagios service is restarted to force the retention.dat file to be updated with the latest information, this ensures that the file is up to date in the backup. This creates a problem with the existing Nagios process and the daily log file rotation that is being performed.
Resolving The Problem
Do not schedule Nagios XI backups to run at midnight, instead schedule them for ten minutes past midnight (00:10).
Final Thoughts
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Moving Your XI Installation
Viewed 5285 times since Tue, Jul 18, 2017
Nagios XI - Backing Up And Restoring Your Nagios XI System
Viewed 26063 times since Wed, Jan 27, 2016
Nagios XI - Restoring A Configuration Snapshot
Viewed 37788 times since Tue, Feb 2, 2016
Nagios XI - Problems with $ Signs in the Check Command
Viewed 12189 times since Tue, Jan 26, 2016
Nagios XI - Core Config Manager - Configuration Snapshots
Viewed 6902 times since Wed, Jul 19, 2017
Nagios XI - Backup and Restore Options
Viewed 24834 times since Mon, Feb 29, 2016
NCPA - Service check timed out after n Seconds
Viewed 17425 times since Tue, Sep 1, 2020
Nagios XI - Scheduled Backups No Longer Working
Viewed 11256 times since Fri, Jun 3, 2016
Nagios XI - Manual Backup And Restore Databases
Viewed 15754 times since Thu, Mar 31, 2016
NCPA - Agent Installation Issue
Viewed 8570 times since Thu, Jan 21, 2016
