Home » Categories » Multiple Categories
Nagios XI - Problems with $ Signs in the Check Command
Problem Description
Certain services in Microsoft Windows use special characters in the service name like MSSQLFDLauncher$UWCX01. This causes problems with Nagios as it thinks the $ is part of a variable.
Resolving The Problem
Using NCPA
Your service definition will need two $$ signs.
MSSQLFDLauncher$$UWCX01
Save and Apply Configuration.
Note: The Test Check Command button will not work due to these special characters.
Using NSClient++
Your service definition will need a backslash \ and two $$ signs.
MSSQLFDLauncher\$$UWCX01
Final Thoughts
1 (8)
Article Rating (8 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Status Information Cut Off At 256 Characters
Viewed 10566 times since Thu, Feb 25, 2016
Nagios XI - Warning: Duplicate definition found for contact ’xi_default_contact’
Viewed 9849 times since Tue, Jan 26, 2016
Nagios XI - STRICT_TRANS_TABLES
Viewed 11590 times since Thu, Nov 16, 2017
WebInject Instructions
Viewed 14962 times since Tue, Mar 16, 2021
Nagios XI - CentOS 6 Installation Problems XI 2011R1.7 2011R1.8
Viewed 6930 times since Tue, Feb 2, 2016
Nagios XI - ERROR: PostgresQL not running - exiting
Viewed 7157 times since Tue, Jan 26, 2016
Nagios XI - Running Out Of Disk Space On The Nagios XI VM
Viewed 28930 times since Tue, Jan 27, 2015
Nagios XI - Monitor Active Directory with LDAP
Viewed 11721 times since Thu, Jan 28, 2016
Nagios XI - Optimizing The PHP Settings File
Viewed 73304 times since Thu, Jul 13, 2017
Nagios XI - Common Upgrade Failures And Solutions
Viewed 17502 times since Thu, Jun 29, 2017
