Home » Categories » Products » Nagios Network Analyzer » Troubleshooting » Common Problems
Nagios Network Analyzer - Top 5 Talkers is not appearing for my device
Problem Description
Any device that implements NetFlow Secure Event Logging (NSEL) instead of a standard sflow or netflow protocol may be affected.
From Cisco's documentation:
NSEL events are used to export data about flow status and are triggered by the event that caused the state change. In stateful flow tracking, tracked flows go through a series of state changes.
Cisco's Adaptive Security Appliance (ASA) is an example of a device that implements NSEL.
Symptoms
Top 5 talkers do not appear on the source's bandwidth graph, while the bandwidth itself appears to be available:
Solutions
Upgrade
This issue was resolved in Nagios Network Analyzer version 2R1.1. If you are able, please download and install the latest Nagios Network Analyzer release.
Compile From Source
If you are not able to upgrade Nagios Network Analyzer, the following commands can be used to recompile nfdump with NSEL support. Please note that previous netflow data may be unavailable after this upgrade.
cd /tmp
wget http://sourceforge.net/projects/nfdump/files/stable/nfdump-1.6.13/nfdump-1.6.13.tar.gz/download
tar xzf download && cd nfdump-1.6.13
./configure--enable-sflow --enable-nsel
make
make install
Final Thoughts
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios Network Analyzer - Graph Says "No Data Available"
Viewed 9849 times since Tue, Jan 27, 2015
Installation errors on customized corporate builds of CentOS or RHEL
Viewed 17137 times since Tue, Jan 26, 2016
Nagios Network Analyzer - My New Source Won’t Start
Viewed 7746 times since Tue, Jan 27, 2015
Active Directory / LDAP - Troubleshooting Authentication Integration
Viewed 24190 times since Mon, Jun 26, 2017
Nagios Network Analzyer - Resetting nagiosadmin Password
Viewed 5861 times since Tue, Dec 11, 2018
Web Browser Reports 330 Error Content Encoding
Viewed 10655 times since Tue, Mar 7, 2017
Nagios Network Analyzer - Understanding The Network Analyzer Backend
Viewed 5902 times since Thu, Jan 28, 2016
Pages Not Displaying Correctly
Viewed 11049 times since Mon, Jan 25, 2016
