Home » Categories » Multiple Categories
Upgrading EOL Operating Systems on a Nagios System
EOL (End of Life) OS releases on Nagios Systems
Because of potential configuration file issues and upgrade-related bugs, we do not recommend or support command line (in-place) operating system release upgrades on your Nagios system. Instead, if you need to upgrade from an EOL operating system release, you should create a backup of your Nagios system and restore the backup to a new system that has the desired operating system installed.
Nagios XI Backup and Restore Documentation
Nagios Log Server Backup and Restore Documentation
Nagios Fusion Backup and Restore Documentation
Nagios Network Analyzer Backup and Restore Documentation
1 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
SSL Certificate does not validate properly
Viewed 7928 times since Wed, Jan 20, 2021
OpenSSL causes issue with check_nrpe plugin with NSClient++
Viewed 15200 times since Fri, Apr 30, 2021
Nagios XI - LDAP / Active Directory - Import Users Certificate Issues
Viewed 12363 times since Tue, Jul 26, 2016
Performance Graphs Showing Data during Host Down Time Periods
Viewed 5070 times since Tue, Dec 7, 2021
SNMP traps are now showing UNKNOWN for the sender IP
Viewed 6754 times since Tue, Jan 19, 2021
VMWare checks timing out or slow
Viewed 6001 times since Fri, Feb 11, 2022
Nagios Log Server - ELK documentation
Viewed 7344 times since Wed, Sep 18, 2019
Nagios Log Server - Upgrading to PHP 7
Viewed 4615 times since Tue, Jan 26, 2021
Forwarding Logs from Nagios Log Server to Another Destination
Viewed 9345 times since Wed, Sep 16, 2020
