Home »
Categories »
Multiple Categories |
Nagios XI - How to Monitor an AKCP SensorProbe2 using SNMP |
Article Number: 241 | Rating: 1/5 from 2 votes | Last Updated by tlea on Tue, Feb 9, 2016 at 10:35 PM
This document describes how to monitor an AKCP sensorProbe2 device with Nagios® XI™ in order to be alerted when temperature, humidity, or other environmental variables exceed specific thresholds.
This document outlines how to monitor the Dual Temperature/Humidity sensor connected to the sensorProbe2, however various AKCP intelligent sensors can be connected via the RJ45 connectors to the sensorProbe devices and then monitored in Nagios XI in a similar manor.
Documentation - How to Monitor an AKCP SensorProbe2 using SNMP
Final Thoughts
Have a question? Try our Forums! | Give Feedback |
1 (2)
Article Rating (2 Votes)
Rate this article
| Related Articles
Nagios XI - Monitoring MongoDB
Viewed 5045 times since Thu, Jan 28, 2016
Nagios XI - Hostgroup Inheritance
Viewed 5372 times since Wed, Jul 19, 2017
Nagios XI - WatchGuard Wizard Usage
Viewed 5000 times since Thu, Jan 28, 2016
Nagios XI - How to Use the NSCA Addon
Viewed 6752 times since Thu, Jan 28, 2016
