Home » Categories » Multiple Categories
Nagios XI - Monitoring Performance Counters in Nagios Using NCPA
This article describes how you can monitor Windows Performance Counters in Nagios XI. This article will show you how to do this using Core Configuration Manager (CCM).
This article is going to focus on the following performance counter:
"\Memory\Available MBytes"
Which is referenced by NCPA in the following format:
'windowscounters/Memory/Available%20MBytes'
Note: When spaces are involved, %20 is required to emulate the space:
Warning threshold will be set to 500 and critical 256.
Requirements
You need to install NCPA to be able to monitor performance counters in Nagios XI. Please refer to the installing NCPA KB article if you have not already done so.
You will also need to have the host already monitored by Nagios XI (you can do this using the NCPA wizard). In this example, the host is called win7-01 and the host has the token uumrdrd3p704.
Create The Service
Click the Configure menu
Click Core Configuration Manager
In the left pane under Monitoring click Services
Click the Add New button
Populate the fields on each tab as follows:
Common Settings
Config Name win7-01
Description Memory Available
Manage Hosts button Select win7-01
Manage Templates button Select xiwizard_ncpa_service
Check command check_xi_ncpa_agent
$ARG1$ -t 'uumrdrd3p704' -P 5693 -M 'windowscounters/Memory/Available%20MBytes' -w 500: -c 256:
Check Settings
Check interval 5
Retry interval 1
Max check attempts 5
Check period xi_timeperiod_24x7
Alert Settings
Complete any notification options as required
Click Save
Click Apply Configuration
Now the settings have been applied, click the magnifying glass on the right of the menu bar.
Search for Memory Available
In the search result, click on the new service Memory Available
You should see something like the following:
This completes monitoring a performance counter using NCPA.
Summary
At this point you should have an understanding of how to configure Nagios XI to monitor performance counters.
Final Thoughts
2.33 (3)
Article Rating (3 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - WatchGuard Wizard Usage
Viewed 6817 times since Thu, Jan 28, 2016
Nagios XI - How to Integrate the Bischeck Plugin Extension with Nagios XI
Viewed 5963 times since Thu, Jan 28, 2016
Nagios XI - Nagios Agents
Viewed 12413 times since Wed, Jan 28, 2015
Nagios XI - Installing the XI Mac OS/X Agent
Viewed 8087 times since Wed, Jan 27, 2016
Nagios XI - Managing Plugins In Nagios XI
Viewed 18723 times since Thu, Jan 28, 2016
Nagios XI - Group Deployment of Service Checks - NWC15
Viewed 8147 times since Mon, Feb 8, 2016
Nagios XI - Monitoring VMware Virtualization Using vMA - NWC14
Viewed 9171 times since Thu, Feb 4, 2016
Nagios XI - Problems with $ Signs in the Check Command
Viewed 10773 times since Tue, Jan 26, 2016
Nagios XI - Monitoring Windows With SNMP
Viewed 12921 times since Tue, Jul 18, 2017
Nagios XI - Core Config Manager - How It Works
Viewed 6109 times since Sun, Jul 30, 2017
