Home » Categories » Multiple Categories
OpenSSL causes issue with check_nrpe plugin with NSClient++
The Problem
The new openssl package on the latest versions of Centos / RHEL/ Ubuntu / Debian cause compatibility issues that cause the check_nrpe plugin to fail when checking Windows Hosts running NSClient++.
Error Displayed
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with xxx.xxx.xxx.xxx: 1
Error in the nsclient.log file
Failed to establish secure connection: sslv3 alert handshake failure: 1040
Solution
To fix this, do the following:
1. Generate DH key on the new Nagios server. (It will take a long time to generate so be patient)
For OpenSSL >= 3.0
openssl dhparam 2048 2> /dev/null|sed -n '/BEGIN/,/END/p'
For OpenSSL < 3.0
openssl dhparam -C 2048 2> /dev/null|sed -n '/BEGIN/,/END/p'
The below is an example of the output:
-----BEGIN DH PARAMETERS-----
MIIBCAKCAQEAsT8ZYluOSVjB67zI8HXRzAjVRsBGLktGbUm7Zfhtn5dYTMaEjSRx
+7McBGnmoJa9ty54UE/5/8rM1CFvA5VyEOakZHemTNvAofB40ZmEhgANVmbHZxtr
egvj4svxnvFM4gAfpsSe2C8DVbXXEJlUVfyacbfb4f9ko0l62XsTEQJGWGRxXca7
b66g5MY6eYxihavufmZmZPw4ZnBPEpoGpH2GKZ0obOEfACTrV01p+CbiVDJ9lpc7
KOxbXA+3nV5LRMSjlz83RuDdQ3QLcQQQ7cpWKEzAlHO/AO4BRqthmSBkTVWNeHoO
a4PNgZO2xdnLHJuK75YQJeLAOKI9xVgaCwIBAg==
-----END DH PARAMETERS-----
2. Paste the DH key to a new file "nrpe_dh_2048.pem" on the Windows server in the following location:
C:\Program Files\NSClient++\security\nrpe_dh_2048.pem
3. Open a command prompt in Windows (under user with admin privileges) and run these commands:
cd "\Program Files\NSClient++"
nscp settings --path /settings/NRPE/server --key dh --set "${certificate-path}/nrpe_dh_2048.pem"
Or add the below under the [/settings/NRPE/server] section in the C:\Program Files\NSClient++\nsclient.ini file:
; DH KEY -
dh = ${certificate-path}/nrpe_dh_2048.pem
4. Restart NSClient++ service
net stop nscp && net start nscp
Test it:
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -2
I (0.5.0.62 2016-09-14) seem to be doing fine...
1 (6)
Article Rating (6 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Error while converting SVG
Viewed 6546 times since Thu, Aug 3, 2017
CCM says unapplied changes exist, but none listed
Viewed 8258 times since Mon, Feb 27, 2017
VMWare checks timing out or slow
Viewed 6002 times since Fri, Feb 11, 2022
NRPE - Agent and Plugin Explained
Viewed 79937 times since Fri, Jul 14, 2017
Nagios XI - ERROR: unable to open include file: conf.d/*.cfg
Viewed 11579 times since Sun, May 29, 2016
Nagios XI - Disabling Database UTF8 Connectivity
Viewed 7254 times since Thu, Mar 8, 2018
Nagios XI - NSP: Sorry Dave, I can’t let you do that
Viewed 25748 times since Tue, Jan 27, 2015
Nagios XI - Migrate Performance Data
Viewed 16395 times since Tue, Jan 26, 2016
Enabling Oracle Linux Optional Repository
Viewed 22079 times since Mon, May 14, 2018
NDOUtils - Message Queue Exceeded
Viewed 19504 times since Thu, Jan 21, 2016
