Home » Categories » Support Documents » Technical and Support Anouncements
Max check attempts required field is missing issue
When you create or modify a host or service, you may see an error if you did not enter anything in the Max Checks Attempt field, in the Check Settings tab. We have seen this on Nagios XI 2024R1.4.2 and XI 2024R1.4.3.
We have made some changes that validate those settings, which in turn is causing the error.
The solution, is to edit the check_settings.php file:
Edit this file:
/usr/local/nagiosxi/html/includes/components/ccm/page_templates/check_settings.php
Change Line 61 from
<input name="tfMaxCheckAttempts" class="form-control required" type="text" id="tfMaxCheckAttempts" value="<?php echo encode_form_val(grab_array_var($FIELDS, 'max_check_attempts', '    ')); ?>">
to
<input name="tfMaxCheckAttempts" class="form-control" type="text" id="tfMaxCheckAttempts" value="<?php echo encode_form_val(grab_array_var($FIELDS, 'max_check_attempts', '    ')); ?>">
Log out and back into XI, or restart Apache  for the fix to take hold.
We expect to fix this issue in an upcoming version of XI.
Please make sure to monitor our change logs for updates: https://www.nagios.com/changelog/
5 (1)
Article Rating (1 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Upgrade error with XI and non-standard Broker Modules
Viewed 2663 times since Thu, Nov 14, 2024
Linux Distributions Reaching End of Life
Viewed 6204 times since Fri, Dec 27, 2024
/usr/local/nagiosxi/var/xi-itype: No such file or directory error
Viewed 2493 times since Thu, Nov 14, 2024
Nagios Software Matrix
Viewed 32260 times since Tue, Nov 12, 2024
Login screen flashes after upgrade to XI 2024R1.4.2
Viewed 1644 times since Mon, May 19, 2025
404 errors after upgrade from 2024R1.1.2 to 2024R1.1.3
Viewed 2103 times since Thu, Nov 14, 2024
XI 5.10.0 and newer Postgress to MySQL Conversion
Viewed 2394 times since Fri, Mar 7, 2025
Error: Invalid max_check_attempts value for host
Viewed 4011 times since Thu, Nov 14, 2024
Overcoming lack of VMware SDK with VMware Wizard
Viewed 8972 times since Wed, Nov 13, 2024
