Home » Categories » Support Documents » Technical and Support Anouncements
XI 5.10.0 and newer Postgress to MySQL Conversion
The Nagios XI default database changed from PostgreSQL to MySQL, since the initial release of XI 5.  If you see a notice after upgrading XI on your server to version 5.10.0, or later, to convert your PostgreSQL database to MySQL, it means you are still on PostgreSQL (maybe due to original installation being pre - XI 5).
The following process will guide you through a successful migration of the PostgreSQL database to the MYSQL database. Please note to only run this script on your XI 5.10.x or XI 5.11.x installation. Please make sure you have upgraded to one of those versions first, before proceeding.
Make sure to back up your XI instance first, using this document: Backing up and Restoring Nagios XI
Open a root ssh session to the Nagios server and look in the
/etc/my.cnf
file or the
/etc/my.cnf.d/mysql-server.cnf
file (your server will have one or the other) for the following option:
max_allowed_packet=256M
If it is not defined, then under this section
[mysqld]
Add this
Save the change and run this command to restart the MYSQL or MariaDB database.
systemctl restart mariadb || systemctl restart mysqld
Change the directory:
cd /usr/local/nagiosxi/scripts/pg2mysql/
Run this to download the conversion script.
wget https://assets.nagios.com/downloads/support/convert_mod.zip
Unzip the downloaded file by running this command:
unzip convert_mod.zip
Then run the following command to convert the nagiosxi database from PostgreSQL to MYSQL and setup the server to point to the database in MYSQL.
In the command to perform the conversion, it uses nagiosxi as the root password for the mysql database, if it was changed on your server, use your password instead of this example.
Run this command to set the script executable.
chmod a+x convert_mod.php
Then run this command to perform the conversion.
./convert_mod.php localhost root nagiosxi
After the script has finished, you can log back in to the XI interface and make sure everything is working correctly.
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios Software Matrix
Viewed 32260 times since Tue, Nov 12, 2024
Overcoming lack of VMware SDK with VMware Wizard
Viewed 8972 times since Wed, Nov 13, 2024
Login screen flashes after upgrade to XI 2024R1.4.2
Viewed 1644 times since Mon, May 19, 2025
Error: Invalid max_check_attempts value for host
Viewed 4011 times since Thu, Nov 14, 2024
Max check attempts required field is missing issue
Viewed 2167 times since Thu, May 22, 2025
404 errors after upgrade from 2024R1.1.2 to 2024R1.1.3
Viewed 2103 times since Thu, Nov 14, 2024
Upgrade error with XI and non-standard Broker Modules
Viewed 2663 times since Thu, Nov 14, 2024
Linux Distributions Reaching End of Life
Viewed 6204 times since Fri, Dec 27, 2024
/usr/local/nagiosxi/var/xi-itype: No such file or directory error
Viewed 2493 times since Thu, Nov 14, 2024
