Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
Nagios XI - CentOS 6 Installation Problems XI 2011R1.7 2011R1.8
Problem Description
Between the the release of Nagios XI 2011R1.7 and 1.8, several changes were made to the CentOS 6 repo that created package conflicts, preventing the Nagios XI installation scripts from completing successfully. This usually becomes apparent by the "fullinstall" script failing with one of the following two messages:
ERROR: Prerequisite program 'mysql' not found!
which: no mysqladmin in (/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:   /usr/sbin:/sbin:/home/admin/bin)
ERROR: Prerequisite program 'mysqladmin' not found!
7 prerequisite(s) missing - exiting.
 OR
ls: cannot access /usr/local/nagiosxi/nom/checkpoints/nagioscore/*.gz: No such file or directory
NO NOM SNAPSHOT FOUND!
ERROR: NagiosQL import appears to have failed - exiting.  (Reason: Import files are still present in /usr/local/nagios/etc/import)
Resolving The Problem
This issue can be resolved with the following solution if you're attempting to install with the 1.7 tarball. This problem will be resolved in the 2011R1.8 release of Nagios XI.
Before attempting any more installations, run:
yum install centos-release-cr
Then remove any previous /tmp/nagiosxi directory that is in place, and unpack a fresh tarball:
cd /tmp
rm -rf nagiosxi
tar zxf xi-2011r1.7.tar.gz
cd nagiosxi
./fullinstall
 If the installer still fails, contact XI support and attach the install.log file that's generated by the fullinstall script.
Final Thoughts
1 (1)
Article Rating (1 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - How To Test Check Commands From The Command-line
Viewed 57033 times since Tue, Jan 26, 2016
Nagios XI - Oracle Services Critical After Nagios XI Upgrade
Viewed 8327 times since Wed, Jan 27, 2016
Nagios XI - Notification Problems
Viewed 35734 times since Tue, Jan 27, 2015
Backups are not being generated due to tar creation errors
Viewed 5964 times since Thu, Feb 27, 2020
Nagios XI - SNMPTT Service generates Cannot find module errors
Viewed 8839 times since Sun, Apr 9, 2017
Nagios XI - Apply Configuration Never Completes
Viewed 26340 times since Tue, Jan 27, 2015
Nagios XI - Troubleshooting Reports
Viewed 10135 times since Wed, Dec 5, 2018
Nagios XI - Event Data Is Stale
Viewed 8029 times since Wed, Jan 27, 2016
Nagios XI - MK Livestatus Problems With Mod-Gearman
Viewed 8148 times since Thu, Feb 25, 2016
Nagios XI - SQL Error [nagiosxi] : ERROR: syntax error
Viewed 10822 times since Sun, Sep 10, 2017
