Home » Categories » Products » Nagios XI » Documentation » Configuration Wizards
Nagios XI - How To Monitor Docker Containers
How To Monitor Docker Containers With Nagios XI
This document below describes how to use the Docker Configuration Wizard to monitor your containers' status and resource usage with Nagios XI.
Note: In order to check the health of a docker container there must be a health check configured. See How to Add a Health Check to Your Docker Container for more information.
Documentation - How To Monitor Docker Containers With Nagios XI
Final Thoughts
1 (1)
Article Rating (1 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Installing The Linux Agent
Viewed 18598 times since Wed, Jan 27, 2016
Nagios XI - Core Config Manager - Escalation Wizard
Viewed 6612 times since Sun, Jul 30, 2017
Nagios XI - Monitoring A Nagios XI Server
Viewed 7628 times since Thu, Jan 28, 2016
Monitoring Amazon EC2
Viewed 8141 times since Thu, Jul 29, 2021
Nagios XI - Monitoring TCP/UDP Ports
Viewed 10956 times since Wed, Jul 19, 2017
Nagios XI - Monitoring Unconfigured Objects
Viewed 9429 times since Thu, Jan 28, 2016
Nagios XI - Monitoring Hosts Using SSH
Viewed 11875 times since Thu, Jan 28, 2016
Nagios XI - Monitoring A MySQL Server
Viewed 9514 times since Wed, Jul 19, 2017
Nagios XI - Monitoring An LDAP Server
Viewed 5824 times since Wed, Jul 19, 2017
Nagios XI - Using Nagios XI As A Security Tool - Website Defacement
Viewed 5650 times since Wed, Jul 19, 2017
