Home » Categories » Products » Nagios XI » Documentation » Monitoring Configuration
Nagios XI - Understanding And Using Configuration Wizards
Understanding And Using Configuration Wizards In Nagios XI
This document is intended for use by Nagios Administrators that wish to get a thorough understanding of how
Configuration Wizards work in Nagios XI.
Documentation - Understanding And Using Configuration Wizards In Nagios XI
This video introduces you to Configuration Wizards which are very easy to set up configuration settings for certain items you want to monitor inside your network. Watch Aaron do a step-by-step guide on how to set these up.
In this video, we continue to work our way through a Nagios XI configuration wizard to help users understand how they work and give them an example so they can easily monitor their own environment.
In this video, we focus on the last step of the configuration wizard process, specifically concerning host groups, service groups and parent child relationships.
Watch this video to learn about a way to quickly add a new element to your monitoring environment with Configuration Wizard Templates.
Final Thoughts
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - How to Use the NSCA Addon
Viewed 10509 times since Thu, Jan 28, 2016
NRPE - Agent and Plugin Explained
Viewed 79937 times since Fri, Jul 14, 2017
Automatic Agent Deployment
Viewed 15045 times since Wed, Jun 3, 2020
Nagios XI - Monitoring Hosts Using SSH
Viewed 11874 times since Thu, Jan 28, 2016
Nagios XI - Using The Config Import Prep Tool
Viewed 14778 times since Thu, Jan 28, 2016
Nagios XI - Core Config Manager - Escalation Wizard
Viewed 6611 times since Sun, Jul 30, 2017
Nagios XI - Monitoring Apache Tomcat With XI
Viewed 6795 times since Wed, Jan 27, 2016
Nagios XI - Installing The AIX Agent
Viewed 10851 times since Wed, Jan 27, 2016
Nagios XI - Using The Core Config Manager For Host Management
Viewed 10742 times since Thu, Jan 28, 2016
Nagios XI - Monitoring Windows With NCPA
Viewed 10467 times since Wed, Jul 19, 2017
