Home » Categories » Products » Nagios XI » Documentation » Advanced Topics
Database Storage Engine and High CPU usage in Nagios XI
Storage Engine Overview
A storage engine is a software module that a database management system uses to create, read, update data from a database.
For MySQL 5.5 and later, the default storage engine is InnoDB. The default storage engine for MySQL prior to version 5.5 was MyISAM.
InnoDB is the most widely used storage engine with transaction support. It supports row-level locking, crash recovery and multi-version concurrency control. It is the only engine which provides foreign key referential integrity constraint.
MyISAM is the original storage engine. It is a fast storage engine. It is used mostly in Web and data warehousing.
If your database tables have a proclivity for crashing, it is better to use InnoDB as the storage engine. For more information, read the following:
Benefits of using InnoDB
Checking Storage Engine Type
Run the following within mysql to determine the storage engine type for your database:
USE <database>;
SHOW TABLE STATUS\G
Nagios XI Databases
Database Name Default Storage Engine
nagios MyISAM
nagiosxi InnoDB
nagiosql InnoDB
Potential Nagios XI Symptoms
Your server is very slow and operates at high CPU. You also experience crashed tables frequently and must run the Nagios XI repair script to solve the error on a regular basis.
Possible Solution
Please read this article below to ensure that the steps presented in the article do not fix your issue before attempting the commands below:
Crashed Database Tables
Note: Ensure that you create a backup before attempting the below database commands.
The following commands will convert the storage engine to InnoDB for all Nagios XI tables. This should decrease the probability of crashed tables and other table errors that may cause high cpu usage.
mysql -h 127.0.0.1 -uroot -pnagiosxi nagios -e "SELECT CONCAT('ALTER TABLE ', table_name, ' ENGINE=InnoDB;') as '' FROM information_schema.tables AS tb WHERE table_schema = 'nagios' AND ENGINE = 'MyISAM' AND TABLE_TYPE = 'BASE TABLE' ORDER BY table_name DESC;" > /tmp/nagios_convert_myisam_to_innodb.sql
mysql -h 127.0.0.1 -uroot -pnagiosxi nagiosql -e "SELECT CONCAT('ALTER TABLE ', table_name, ' ENGINE=InnoDB;') as '' FROM information_schema.tables AS tb WHERE table_schema = 'nagiosql' AND ENGINE = 'MyISAM' AND TABLE_TYPE = 'BASE TABLE' ORDER BY table_name DESC;" > /tmp/nagiosql_convert_myisam_to_innodb.sql
mysql -h 127.0.0.1 -uroot -pnagiosxi -e "SELECT CONCAT('ALTER TABLE ', table_name, ' ENGINE=InnoDB;') as '' FROM information_schema.tables AS tb WHERE table_schema = 'nagiosxi' AND ENGINE = 'MyISAM' AND TABLE_TYPE = 'BASE TABLE' ORDER BY table_name DESC;" > /tmp/nagiosxi_convert_myisam_to_innodb.sql
mysql -h 127.0.0.1 -uroot -pnagiosxi nagios < /tmp/nagios_convert_myisam_to_innodb.sql
mysql -h 127.0.0.1 -uroot -pnagiosxi nagiosql < /tmp/nagiosql_convert_myisam_to_innodb.sql
mysql -h 127.0.0.1 -uroot -pnagiosxi nagiosxi < /tmp/nagiosxi_convert_myisam_to_innodb.sql
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Migrating From Nagios Core
Viewed 8895 times since Thu, Jan 28, 2016
Nagios XI - Group Deployment of Service Checks - NWC15
Viewed 9168 times since Mon, Feb 8, 2016
Nagios XI - Understanding Email Sending
Viewed 14575 times since Tue, May 2, 2017
Nagios XI - Resizing the VM Disk Size
Viewed 16307 times since Thu, Jan 28, 2016
Managing Host Templates
Viewed 13431 times since Mon, Jun 28, 2021
Nagios XI - Integrating On-Call Schedules with Nagios - NWC13
Viewed 8322 times since Tue, Feb 9, 2016
Nagios Core - Nagios as a PC Health Monitor - NWC14
Viewed 13864 times since Tue, Feb 9, 2016
Nagios Core - SNMP Explained - NWC15
Viewed 17918 times since Mon, Feb 8, 2016
Nagios XI - Understanding User Macros
Viewed 9773 times since Thu, Jan 28, 2016
PHP 7.2 to 7.4 Upgrade Instructions for RHEL 8 & Oracle 8
Viewed 9237 times since Wed, Feb 2, 2022
