Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
XI 5.4 monitoring engine not running
Problem:
In Nagios XI versions 5.4.0 and 5.4.1 there was a bug in the included Nagios Core version which caused a segmentation fault (crash) in some systems.
Resolution:
First and foremost, please take an XI backup (and a VM snapshot if possible) so that you can revert if necessary:
https://assets.nagios.com/downloads/nagiosxi/docs/Backing-Up-And-Restoring-Nagios-XI.pdf
We have fixed the segfault issue, and you can run the following commands to fix this on a running 5.4.0 or 5.4.1 system:
Then transfer the attached file to your XI server and run these commands from the directory containing the patch:
service nagios stop
killall -9 nagios
service ndo2db stop
service mysqld restart
for i in `ipcs -q | grep nagios |awk '{print $2}'`; do ipcrm -q $i; done
tar zxf ndoutils_segfault_patched.tar.gz
cd ndoutils_segfault_patched
./upgrade
1 (3)
Article Rating (3 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments (1) Attachments
Related Articles RSS Feed
Nagios XI - ERROR: PostgresQL not running - exiting
Viewed 7157 times since Tue, Jan 26, 2016
Pages Not Displaying Correctly
Viewed 11069 times since Mon, Jan 25, 2016
Web Browser Reports 330 Error Content Encoding
Viewed 10668 times since Tue, Mar 7, 2017
Backups are not being generated due to tar creation errors
Viewed 5964 times since Thu, Feb 27, 2020
Nagios XI - Running Out Of Disk Space On The Nagios XI VM
Viewed 28930 times since Tue, Jan 27, 2015
Nagios XI - Core Configuration Mananger Display Issues
Viewed 7059 times since Tue, Jan 26, 2016
Nagios XI - Notification Problems
Viewed 35734 times since Tue, Jan 27, 2015
Nagios XI - Crashed Database Tables
Viewed 70258 times since Tue, Jan 27, 2015
Nagios XI - MRTG Reports SNMP_Session Errors
Viewed 8854 times since Wed, Jul 27, 2016
Slack Notifications Stopped Working
Viewed 6757 times since Wed, Mar 18, 2020
