Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
Nagios XI - Scheduled Reports Not Running
Problem Description
This KB article helps fix scheduled reports that are not running, you are not receiving the email that should be sent out.
Troubleshooting
The first step is to check the contents of the apache crontab file with the following command:
cat /var/spool/cron/apache
Once you've done this, go and schedule a report as a test.
After that, execute the command above to view the crontab file again.
If there is no change in the output, execute the following command:
grep crontab /var/log/httpd/*
If you see this error message:
You (apache) are not allowed to use this program (crontab)
The cron.allow file needs updating to resolve this issue.
Execute the following command to add the apache user to the /etc/cron.allow file:
echo apache >> /etc/cron.allow
Once you have made this change, go schedule the report again and the /var/spool/cron/apache should now be updated.
Final Thoughts
1 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Unable to Delete Host
Viewed 27794 times since Tue, Dec 16, 2014
Nagios XI - Problems Using Nagios XI With Proxies
Viewed 17807 times since Mon, Jan 25, 2016
Nagios XI - Scheduled Downtime Not Working
Viewed 10073 times since Mon, Oct 10, 2016
Nagios XI - Performance Graph Problems
Viewed 33245 times since Fri, Dec 19, 2014
Nagios XI - Oracle Services Critical After Nagios XI Upgrade
Viewed 8327 times since Wed, Jan 27, 2016
Nagios XI - Empty Screen for Wizard, Component, Dashlet
Viewed 10471 times since Wed, Jan 27, 2016
Nagios XI - Core Configuration Mananger Display Issues
Viewed 7059 times since Tue, Jan 26, 2016
NDOUtils - Message Queue Exceeded
Viewed 19504 times since Thu, Jan 21, 2016
Nagios XI - 2014 Upgrade Issue - CONFIG ERROR
Viewed 8059 times since Mon, Jan 25, 2016
Nagios XI - SourceGuardian Errors 2009R1.2C
Viewed 6379 times since Tue, Feb 2, 2016
