Home » Categories » Multiple Categories
Nagios XI - SNMP MIB Upload Problems
Overview
This KB article provides solutions to issues that can arise when uploading SNMP MIB files.
Permissions
Some problems are caused by incorrect permissions on the SNMP MIB files.
If you receive one of these errors:
failed to convert to snmptt mib
MIB could not be installed - directory permissions may be incorrect.
Execute the following commands to reset the permissions and ownership:
chmod -R ug+rw /usr/share/snmp/mibs
chown -R root:nagios /usr/share/snmp/mibs
After executing those commands you should be able to upload the MIB file that previously did not work.
Modules Missing
MIBs can require modules that are defined in other MIBs. If you have uploaded a MIB to Nagios XI and the required modules are missing, you might notice some warnings when executing Net-SNMP commands in a terminal session.
For example, after uploading the MIB CISCO-IMAGE-MIB.my file you receive these warnings when using the snmpwalk command:
MIB search path: /root/.snmp/mibs:/usr/share/snmp/mibs
Cannot find module (CISCO-SMI): At line 24 in /usr/share/snmp/mibs/CISCO-IMAGE-MIB.my
Did not find 'ciscoMgmt' in module #-1 (/usr/share/snmp/mibs/CISCO-IMAGE-MIB.my)
Unlinked OID in CISCO-IMAGE-MIB: ciscoImageMIB ::= { ciscoMgmt 25 }
Undefined identifier: ciscoMgmt near line 27 of /usr/share/snmp/mibs/CISCO-IMAGE-MIB.my
In the error above the CISCO-SMI module appears to be missing. After uploading the MIB CISCO-SMI.my file you will not receive the warnings.
The explanation is that the Net-SNMP commands look at all the MIB files in the /usr/share/snmp/mibs/ folder when executing. The commands will display warnings if the modules are missing. You don't often see these warnings in the Nagios XI interface as this output is hidden, you commonly only see the warnings when in a terminal session.
It's worth mentioning that the filename "CISCO-SMI.my" is not how Net-SNMP knows that the the module is located in this file. This line in the file defines it:
CISCO-SMI DEFINITIONS ::= BEGIN
The fact that the file is named "CISCO-SMI.my" is irrelevant, however Cisco have made it easy by keeping the filename the same as the module definition name.
Final Thoughts
1.83 (6)
Article Rating (6 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Apply Configuration Fails - Backend login to the Core Configuration failed
Viewed 29136 times since Tue, Aug 2, 2016
Nagios XI - MK Livestatus Problems With Mod-Gearman
Viewed 8147 times since Thu, Feb 25, 2016
CCM says unapplied changes exist, but none listed
Viewed 8258 times since Mon, Feb 27, 2017
Nagios XI - Update Default snmptt.conf EVENT
Viewed 11027 times since Mon, Nov 28, 2016
XI 5.4 monitoring engine not running
Viewed 14262 times since Mon, Feb 6, 2017
Nagios XI - Installing Latest SourceGuardian Loaders
Viewed 10988 times since Mon, Jun 18, 2018
Turning Off PHP Notices and Deprecated Messages
Viewed 6922 times since Wed, Oct 20, 2021
Nagios XI - Modifying The Contents Of /usr/local/nagios/etc
Viewed 10315 times since Tue, Jan 26, 2016
Installation errors on customized corporate builds of CentOS or RHEL
Viewed 17160 times since Tue, Jan 26, 2016
Upgrading to NDO 3 after having been downgraded in newer versions of Nagios XI
Viewed 6404 times since Fri, Jan 15, 2021
