Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
Nagios XI - Core 4 Load Spikes on 1.75 and 7 Hour Intervals
Problem Description
With the release of Nagios XI 2014 the core version on the back-end was updated to Core 4. This introduced a issue in certain environments where an extremely high system level load can occur at intervals most commonly between an hour and seven hours of the Nagios process starting.
Editing Files
In many steps of this article you will be required to edit files. This documentation will use the vi text editor. When using the vi
editor:
  • To make changes press i on the keyboard first to enter insert mode
  • Press Esc to exit insert mode
  • When you have finished, save the changes in vi by typing :wq and press Enter
Resolving The Problem
As a temporary solution to this we recommend that if you have been experiencing this problem, you should modify:
/usr/local/nagiosxi/html/config.inc.php
By changing the following line:
"nom_checkpoint_interval" => 1440, // time (in minutes) between nom checkpoints
To:
"nom_checkpoint_interval" => 90, // time (in minutes) between nom checkpoints
You may want to alter the above noted interval based on when you are experiencing these problems.
Ideally it should be set to occur as close to the high load anomaly as possible as to minimize system downtime and stress while we work towards a more permanent solution.
This will force the creation of a snapshot, so you may want to archive any important config snaphots as these changes will increase the number of daily snapshots (possibly pushing needed snapshots from the pool).
Final Thoughts
1 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - MSSQL Wizards - Adaptive Server connection failed
Viewed 14566 times since Thu, Aug 3, 2017
Nagios XI - Warning: Duplicate definition found for contact ’xi_default_contact’
Viewed 9850 times since Tue, Jan 26, 2016
NRPE - Agent and Plugin Explained
Viewed 79937 times since Fri, Jul 14, 2017
Nagios XI - Notification Problems
Viewed 35734 times since Tue, Jan 27, 2015
Nagios XI - Performance Graph Problems
Viewed 33245 times since Fri, Dec 19, 2014
Nagios XI - Crashed Database Tables
Viewed 70258 times since Tue, Jan 27, 2015
Pages Not Displaying Correctly
Viewed 11069 times since Mon, Jan 25, 2016
Nagios XI - Modifying The Contents Of /usr/local/nagios/etc
Viewed 10315 times since Tue, Jan 26, 2016
Nagios XI - Login Screen Keeps Redirecting To Itself
Viewed 9347 times since Wed, Jan 27, 2016
Nagios XI - Apply Configuration Fails - Backend login to the Core Configuration failed
Viewed 29137 times since Tue, Aug 2, 2016
