Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
Nagios XI - Some BPI Checks Show "Unknown BPI Group Index" After Upgrade
Problem Description
When upgrading Nagios XI above version 5.6.5, BPI checks which were dependent on hostgroups or servicegroups would change from their usual status to "Unknown BPI Group Index"..
Resolution
The fix for this issue involves editing affected checks in the Core Config Manager. Modify affected hosts and services by going to Configure -> Core Config Manager, and clicking "Hosts" or "Services", then clicking the "Edit" button  (wrench icon) to the right of the affected host or service.
You will need to edit the host or service and prepend the $ARG1$ value with hg_ (if it's a hostgroup) or prepend it with sg_ (if it's a servicegroup).
After editing, click the "Run Check Command" button to verify that the new command works. After the change has been applied to all affected hosts and services, go to Quick Tools -> Apply Configuration to finalize your changes.
1 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Uploaded plugin returns "/bin/bash^M: bad interpreter: No such file or directory"
Viewed 10770 times since Thu, Feb 25, 2016
Nagios XI - Resolving "Cannot connect to database" Error - Core Config Manager
Viewed 10978 times since Mon, Jan 25, 2016
Nagios XI - Troubleshooting Reports
Viewed 10187 times since Wed, Dec 5, 2018
Nagios XI - Crashed Database Tables
Viewed 70422 times since Tue, Jan 27, 2015
Nagios XI - 2014 Upgrade Issue - CONFIG ERROR
Viewed 8117 times since Mon, Jan 25, 2016
Slack Notifications Stopped Working
Viewed 6810 times since Wed, Mar 18, 2020
Nagios XI - Downloading A System Profile
Viewed 10952 times since Wed, Jul 19, 2017
Nagios XI - Login Screen Keeps Redirecting To Itself
Viewed 9405 times since Wed, Jan 27, 2016
Nagios XI - MRTG Reports SNMP_Session Errors
Viewed 8920 times since Wed, Jul 27, 2016
Nagios XI - MSSQL Wizards - Adaptive Server connection failed
Viewed 14646 times since Thu, Aug 3, 2017
