Home » Categories » Multiple Categories
Nagios XI - MK Livestatus Problems With Mod-Gearman
This article has been retired due to obsolescence and is no longer used. Please visit Support.nagios.com for additional resources.
Please note that Mod-Gearman dropped support for Nagios Core in March of 2022. XI integration with Mod-Gearman is also not supported by Nagios Enterprises and future problems caused by using this method are beyond our control.
Multiple Nagios XI instances can be used if the size of your infrastructure or monitoring needs require you to create a distributed monitoring environment. Federated or distributed Nagios XI instances empower you to scale your infrastructure while making it easier to manage large environments and future changes. For more information on using multiple Nagios XI instances to distribute check load, visit Distributed Monitoring with Nagios XI.
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - WMI Authentication Problems
Viewed 7614 times since Thu, Feb 25, 2016
Nagios XI - Host Still Visible After Deletion (Ghost Hosts)
Viewed 15025 times since Tue, Jan 27, 2015
NDOUtils - Message Queue Exceeded
Viewed 19504 times since Thu, Jan 21, 2016
Nagios XI - Scheduled Backup Log Level
Viewed 7852 times since Tue, Apr 18, 2017
Nagios XI - SNMP MIB Upload Problems
Viewed 12431 times since Mon, Apr 10, 2017
Nagios XI - Apply Configuration Never Completes
Viewed 26340 times since Tue, Jan 27, 2015
Nagios XI - Migrate Performance Data
Viewed 16395 times since Tue, Jan 26, 2016
Active Directory / LDAP - Troubleshooting Authentication Integration
Viewed 24220 times since Mon, Jun 26, 2017
Nagios XI - mysql_error out of range value for column
Viewed 9879 times since Tue, Aug 14, 2018
Nagios XI - SNMPTT Service generates Cannot find module errors
Viewed 8839 times since Sun, Apr 9, 2017
