Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
Nagios XI - ERROR: PostgresQL not running - exiting
Problem Description
This anomaly will rarely occur during a VM set up of Nagios XI.
The following is an example of what it may look like:
cp: cannot create regular file `/usr/local/nagiosxi/scripts':
 Read-only file system
chown: cannot access `/usr/local/nagiosxi/scripts/reset_config_perms': No such file or directory
chown: cannot access `/usr/local/nagiosxi/scripts/reset_config_perms.sh': No such file or directory
chmod: cannot access `/usr/local/nagiosxi/scripts/reset_config_perms': No such file or directory
chmod: cannot access `/usr/local/nagiosxi/scripts/reset_config_perms.sh': No such file or directory
/tmp/nagiosxi
Checking PostgresQL status...
ERROR: PostgresQL not running - exiting.
ERROR: Nagios XI database was not setup properly - exiting.
You may try restarting the server but in some cases will have to start the Nagios XI install from the beginning.
Final Thoughts
1 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Debugging Bandwidth Performance Graphs
Viewed 19872 times since Tue, Jan 27, 2015
Slack Notifications Stopped Working
Viewed 6756 times since Wed, Mar 18, 2020
Nagios XI - Migrate Performance Data
Viewed 16395 times since Tue, Jan 26, 2016
Nagios XI - Upgrade errors - root.crontab.orig: cannot overwrite existing file
Viewed 6543 times since Tue, Jan 26, 2016
Nagios XI - How To Delete A Data Source From An RRD File
Viewed 17081 times since Wed, Apr 27, 2016
CCM says unapplied changes exist, but none listed
Viewed 8258 times since Mon, Feb 27, 2017
Nagios XI - Unable to Delete Host
Viewed 27793 times since Tue, Dec 16, 2014
XI 5.4 monitoring engine not running
Viewed 14262 times since Mon, Feb 6, 2017
Nagios XI - Core 4 Load Spikes on 1.75 and 7 Hour Intervals
Viewed 6681 times since Mon, Jan 25, 2016
NDOUtils - Message Queue Exceeded
Viewed 19504 times since Thu, Jan 21, 2016
