Home » Categories » Multiple Categories
Nagios XI - MK Livestatus Problems With Mod-Gearman
This article has been retired due to obsolescence and is no longer used. Please visit Support.nagios.com for additional resources.
Please note that Mod-Gearman dropped support for Nagios Core in March of 2022. XI integration with Mod-Gearman is also not supported by Nagios Enterprises and future problems caused by using this method are beyond our control.
Multiple Nagios XI instances can be used if the size of your infrastructure or monitoring needs require you to create a distributed monitoring environment. Federated or distributed Nagios XI instances empower you to scale your infrastructure while making it easier to manage large environments and future changes. For more information on using multiple Nagios XI instances to distribute check load, visit Distributed Monitoring with Nagios XI.
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Best Practices - NWC15
Viewed 7435 times since Thu, Feb 4, 2016
Nagios Core - How to Think with Nagios to Solve Monitoring Problems - NWC14
Viewed 5633 times since Mon, Feb 8, 2016
Active Directory / LDAP - Troubleshooting Authentication Integration
Viewed 16614 times since Mon, Jun 26, 2017
Nagios XI - WMI Authentication Problems
Viewed 7605 times since Thu, Feb 25, 2016
Disabling Port 113 IDENT Requests
Viewed 4837 times since Tue, Mar 12, 2019
Nagios XI - Disabling Database UTF8 Connectivity
Viewed 4614 times since Thu, Mar 8, 2018
Turning Off PHP Notices and Deprecated Messages
Viewed 3187 times since Wed, Oct 20, 2021
Nagios XI - Some BPI Checks Show "Unknown BPI Group Index" After Upgrade
Viewed 3762 times since Wed, Sep 18, 2019
API changes in Nagios XI 5.7
Viewed 2935 times since Tue, Feb 23, 2021
Nagios XI - Migrate Performance Data
Viewed 10858 times since Tue, Jan 26, 2016
