Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
XI 5.4 monitoring engine not running
Problem:
In Nagios XI versions 5.4.0 and 5.4.1 there was a bug in the included Nagios Core version which caused a segmentation fault (crash) in some systems.
Resolution:
First and foremost, please take an XI backup (and a VM snapshot if possible) so that you can revert if necessary:
https://assets.nagios.com/downloads/nagiosxi/docs/Backing-Up-And-Restoring-Nagios-XI.pdf
We have fixed the segfault issue, and you can run the following commands to fix this on a running 5.4.0 or 5.4.1 system:
Then transfer the attached file to your XI server and run these commands from the directory containing the patch:
service nagios stop
killall -9 nagios
service ndo2db stop
service mysqld restart
for i in `ipcs -q | grep nagios |awk '{print $2}'`; do ipcrm -q $i; done
tar zxf ndoutils_segfault_patched.tar.gz
cd ndoutils_segfault_patched
./upgrade
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments (1) Attachments
Related Articles RSS Feed
Nagios XI - Core Configuration Mananger Display Issues
Viewed 3975 times since Tue, Jan 26, 2016
Nagios XI - Schedulded Backups No Longer Working
Viewed 6898 times since Fri, Jun 3, 2016
Nagios Core - Failed to register iobroker
Viewed 5784 times since Wed, Sep 20, 2017
Nagios XI - WMI Authentication Problems
Viewed 7605 times since Thu, Feb 25, 2016
Nagios XI - Some BPI Checks Show "Unknown BPI Group Index" After Upgrade
Viewed 3762 times since Wed, Sep 18, 2019
Active Directory / LDAP - Troubleshooting Authentication Integration
Viewed 16614 times since Mon, Jun 26, 2017
Nagios XI - MySQL/MariaDB - Max Connections
Viewed 59570 times since Thu, Jun 2, 2016
Nagios Core - Nagios did not exit in a timely manner
Viewed 5937 times since Wed, Jan 27, 2016
Nagios XI - Oracle Services Critical After Nagios XI Upgrade
Viewed 4978 times since Wed, Jan 27, 2016
Nagios XI - Downloading A System Profile
Viewed 6407 times since Wed, Jul 19, 2017
