Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
Nagios XI - Problems Using Nagios XI With Proxies
Overview
We do not officially support Nagios XI when you install and use proxy software that restricts traffic to or from the Nagios XI server. There are several reasons for this. First, Nagios XI requires external access for package installation and updates. Package installation and updates may not work when proxies are configured incorrectly. Additionally, the Nagios XI code makes several internal HTTP calls to the local Nagios XI server to import configuration data, apply configuration changes, process AJAX requests, etc. These functions may not work properly when you deploy a proxy if it is not configured properly, which could result in a non-functional Nagios XI installation.
Solutions
There are two things that need to be configured to make XI installation work with a proxy; the yum and wget configurations. Do both of these before starting anything about the installation process. You will need to access the Nagios XI server in an SSH session to update the following files.
/etc/yum.conf
proxy=http://someproxyserver:port/ # Shouldn't need to be quoted, remember the trailing slash
proxy_username=myname  # The username you authenticate to your proxy with, if applicable
proxy_password=mypass  # The password you provide to your proxy, if applicable
/etc/wgetrc
http_proxy=http://myname:mypass@someproxyserver:port/ # All in one string this time
https_proxy=https://myname:mypass@someproxyserver:port/ # Only required if you have a HTTPS proxy
no_proxy=localhost,127.0.0.0/8,10.0.0.0/8,172.16.0.0/12,192.168.0.0/16 # Hosts to exclude from proxying
Quoting is not needed (or helpful) in any of these, but if you have special characters in passwords (especially : or @) and are having problems you probably need to escape them with backslashes.
Solution Provided By Customer
Here is a proxy install solution reported by forum user TSCAdmin:
  1. Before running any installation script install php-pear package manually
  2. Set proxy for PHP Pear
  3. Run Nagios installation scripts sequentially
  4. Unset system proxy before running E-importnagiosql script
    pear config-set http_proxy 'http://example.com:8080'
Update Check Behind A Proxy
Updates checks are known to fail for systems behind a proxy.
We have a proxy component that should allow the update check to work behind most proxies.
Navigate to Admin > Proxy Configuration to configure the proxy settings.
Final Thoughts
1 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Login Screen Keeps Redirecting To Itself
Viewed 9347 times since Wed, Jan 27, 2016
Nagios XI - STRICT_TRANS_TABLES
Viewed 11590 times since Thu, Nov 16, 2017
Nagios XI - Unable To Login Using Two Factor Authentication
Viewed 12099 times since Tue, Apr 10, 2018
Nagios XI - Scheduled Backups No Longer Working
Viewed 11256 times since Fri, Jun 3, 2016
Nagios XI - HTTP 500 Error / White Screen After Login
Viewed 9195 times since Mon, Feb 29, 2016
Nagios XI - Installing XI Fails To Install Dependency pymssql
Viewed 11138 times since Mon, Oct 17, 2016
Pages Not Displaying Correctly
Viewed 11069 times since Mon, Jan 25, 2016
Disabling Port 113 IDENT Requests
Viewed 8562 times since Tue, Mar 12, 2019
NDOUtils - Message Queue Exceeded
Viewed 19504 times since Thu, Jan 21, 2016
NRPE - Agent and Plugin Explained
Viewed 79937 times since Fri, Jul 14, 2017
